درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام webp image optimization very low ایجاد شده است. این موضوع تا کنون 24 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع webp image optimization very low
I've done lots of 2.3 upgrades and enabled image optimization for webp. I usually leave the default src/config.php value which I believe is 85%. After optimizing all images I usually see a reduction in the attachment usage in the 50% range.
I ran it on one of our sites and the attachment folder went down from 58.2 GB to 53.8GB.
On another site I did the same optimization with the same settings and it reduced it from 40.1GB to 27.3GB. That's more inline with what I've seen previously.
I...
XFFA.IR Bot Image optimization: GIF to Webp, What are the required libraries on the server? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot PHP Fatal error: gd-webp cannot allocate temporary buffer in C:\xampp\htdocs\{x}\src\XF\Image\Gd.php on line 61 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Question about image optimisation/webp فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot copy & paste of image to make an attachment is blocked as webp isn't an allowed extension by default فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image optimisation fails with gd-webp encoding failed فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Featured content and WebP image فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Permission to upload webp image فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot WebP image add-on for XF 2.1 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [tl] WebP Image Integration [Paid] فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot If I turn on WEBP Optimization are my original images lost? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot SVG files inconsistently rasterized to WebP when "Convert images to WebP" is enabled فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XF doesn’t convert animated GIF avatars into WebP? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot WebP Conversion Issue in XenForo 2.2.15 فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Webp attachments فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Convert WebP to PNG with Watermarking in Bulk فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot As a developer are you still supporting WebP fallback images? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Webp download Conversion فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot gif to webp optimization problems فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Question regarding the process of converting attachments from JPG to WEBP فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Webp attachments thumbnails problem فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Converting a ton of images to WEBP فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Fatal Error: gd-webp cannot allocate temporary buffer فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Change the upload / optimise to webp order فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot WebP avatar in ACP فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Images attached in webp format are not cached فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Imagick and WebP فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Do attachment thumbnails not support webp? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Optimizing profile banners and avatars to WebP through CLI does not seem to do anything فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Will you be optimizing images to webp when 2.3 is released? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot webp gif animation lost on upload فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot [DBTech] DragonByte WebP فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot As a end user is there a way to get webp images to work? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot webp <> jpg فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to create WebP reaction icons? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot webp support فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Convert images to webp فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Google WebP Support فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot .webm and .webp, etc فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Image optimization, enhanced image resizing, and more! فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Mosaic Pro - Advanced Dynamic Photo Gallery & Responsive Image Grid فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Unable to upload RAW image formats (.NEF, .DNG, etc.) anywhere in XF/XFMG/XFRM despite allowed extensions فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot XFMG 2.3 Image Metadata Only Shows Filename, Size, and Dimensions — Camera EXIF Missing فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Use first image within WYSIWYG editor if no icon was uploaded فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Preview view of articles with links to media images show broken image icon on preview فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot First clicked image smaller فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Generate Thread / Resource Image with AI فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Embedded image on a page browses correctly only on Chrome but not other browsers فیدخوان خبری از سایت xenforo.com 0
