درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام What is everyone using for translations? ایجاد شده است. این موضوع تا کنون 74 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع What is everyone using for translations?
I've set up a forum for a client that has users in lots of countries, and that country list is growing. The forum is mostly providing support, and it would be nice if users could select to translate a page into their native language automatically.
Currently I'm using Google Translate, per instructions posted here a few years back. It was a simple widget HTML entry and it works even if it requires 2 steps, but as I understand it someday it no longer will, and I (or someone else) will need...
XFFA.IR Bot Upgraded to 2.3.3 and approval queue shows "No additional information available." on everyone فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hi Everyone- Api Unauthorized issue فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Upgrade from 2.1 to 2.2 - now the User Title Ladder is being ignored and everyone is '0'? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hi Everyone - General Questions about XF فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Is there a way to enable push notifications but not have it automatically annoy everyone? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Media add on is still visible to everyone even after I selected "Viewable to registered users" several times فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Hello everyone فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How to set permissions so everyone can see a private forum in the node list but can't view the contents? فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Forcing everyone to view a post on login فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot How do I disable signatures for everyone? فیدخوان خبری از سایت xenforo.com 0
