Is there any benefit to using "Default" as email option or SMTP? (Default doenst work for me for some reason)
درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Is there any benefit to using \"Default\" as email option or SMTP? (Default doenst work for me for some reason) ایجاد شده است. این موضوع تا کنون 191 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Is there any benefit to using \"Default\" as email option or SMTP? (Default doenst work for me for some reason)
Hi Guys!
I tried to set up "Default" email option 2 months ago, but I failed and wasnt able to make it work. I ended up using SMTP. But I wonder: Is there any benefit of using one or other? Which one is the better? And why cant I use Default?
Thanks for the help!
XFFA.IR Bot disallow AI training using the forum's content فیدخوان خبری از سایت xenforo.com 0
