درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Using backspace sometimes removes spaces ایجاد شده است. این موضوع تا کنون 142 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Using backspace sometimes removes spaces
I have seen another thread about this issue, but it seems it was never actually solved.
xenforo.com
So, whenever I am writing anything on xenforo, and say I misspell the word, when I erase the word, the second I clear away the word it immediately clears the space before it, so now whenever I continue typing those two words are put together and I have been getting complaints about it on my...
xenforo.com
xenforo.com
Every now and then, using the backspace results in the space before also being removed.
XFFA.IR Bot Using backspace sometimes removes spaces فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot Editor: Backspace key unexpectedly deletes line-breaks above caret that were created using Shift+Enter فیدخوان خبری از سایت xenforo.com 0
