درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Using forums for client communications ایجاد شده است. این موضوع تا کنون 168 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Using forums for client communications
Today I've started the process of transitioning client communications from sporadic email chains to private sections on my forums. It dawned on me as I was cleaning out my inbox that I tend to miss messages and fall out of email chains more often than I should, yet I never miss anything posted on my forums. I think that speaks to the level of organization a well thought out forum layout can bring to one's digital life... and maybe exposes my laziness at keeping up with emails. :D
In terms...
XFFA.IR Bot Using Chrome/FireFox custom search engine to search your forums. فیدخوان خبری از سایت xenforo.com 0
XFFA.IR Bot SEO Question - Merging forums to have big sections + using filters فیدخوان خبری از سایت xenforo.com 0
