درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Using Reactions data in a thread for discovery (sorting, etc.) ایجاد شده است. این موضوع تا کنون 184 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Using Reactions data in a thread for discovery (sorting, etc.)
Let's use the data of reactions for discovery. Perhaps a sort? But within a thread, for finding funniest post, most helpful answer, etc.
XF has no Q&A, or Best Answer functionality. But we can customize the reactions to ones that suit our communities, like Helpful. Let's take Helpful as the example here. In a long thread of "answers" wouldn't it be nice to be able to find the post with the most Helpful reactions?
Or in a comedic thread, the most laughs?
Likes, Loves, etc.
So this...
XFFA.IR Bot Custom smilies and reactions are causing layout shift if not using sprite mode فیدخوان خبری از سایت xenforo.com 0
