درباره موضوع به تاریخ, موضوعی در دسته فیدخوان خبری از سایت xenforo.com توسط XFFA.IR Bot با نام Using Root as the index to \/community ایجاد شده است. این موضوع تا کنون 143 بازدید, 0 پاسخ و 0 بار واکنش داشته است
نام موضوع Using Root as the index to \/community
Wordpress has a feature where if you have your WP installed in domain.com/wordpress you can still type domain.com to display your site. This is done by copying the .htaccess and index.php files to root and then modifying a line of text in the index.php file.
Is there a way to do this in XF? So if I visit domain.com it will display the index to the forums that are installed in domain.com/community?
XFFA.IR Bot XF-powered homepage in root using nginx rewrites with forum in subfolder فیدخوان خبری از سایت xenforo.com 0
